enable cli write-permission
Description
Enables access to the full CLI on 4120 Series and 4220 Series switches.
Syntax Description
N/A.
Default
N/A.
Usage Guidelines
This command can be used to gain access to the full CLI on 4120 Series and 4220 Series switches. This command should only be used with GTAC guidance. After issuing the command, the full CLI can only be accessed after entering the one-time only password provided by GTAC.
Use this command to enable access to the full CLI on 4120 Series and 4220 Series switches.
The following command enables access to the full CLI:
4120-24MW-4Y-SwitchEngine.1 = enable cli write-permission
EXOS version: 32.7.1.1
Serial Num : FF012335G-00011
System MAC : 40:E3:17:C7:90:00
Challenge  : U*2TquEemKPN6LXpRaAi6CxJLWcPwCY1RWIbNoIou1bXseucF7mLim%FW4Ua2gIIR
             djr+Z2cU7WZLfZgSXqu%vnTFs9zEVJD4NVi9aYmyTMJt5tM/NeJjeS%qBIEpJmcf0
             V7IUIW4oJoqxR9NFJLbB42mMVrBrVnDoA1Pvq5Kzg4mnbeksN2rMGw9bpj6toy%ej
             G*LmZ5cvGthmf1DGGWF1*mqBgpo4En/t14ydU8ID1qIoMEF76H8wK5%Bpgf54KbIe
             MA*EFqaK7SVbyocnJZKFadnQ%fJX7DsIYg/abJzaav6WY8nzCB4Y2CDvHEjGfNXjb
             qIrtnyJMN0ucW5UKg==
Note: Password will be invalidated if not entered correctly in 1 hour or entered incorrectly 3 times.
Enter debug mode password, or press ENTER to cancel:
4120-24MW-4Y-SwitchEngine.2 #
This command was first available in Switch Engine 32.7.1.
Platform Availability
This command is available the 4120 Series and 4220 Series platforms are running Switch Engine.
